Hello Guest it is October 22, 2026, 05:11:12 PM
Author Topic: Mach4 Lathe: Cutting a 7/24 taper for BT30  (Read 13919 times)
Offline Azalin
  •  189 189
« on: August 28, 2018, 07:43:54 AM »
I've been reading this thread for some info and ended up with the initial settings you see in the attached image. I haven't tried it yet. Does this look OK to you?
https://www.practicalmachinist.com/vb/general/what-angle-bt40-taper-272649/
Suat
Offline Azalin
  •  189 189
Re: Mach4 Lathe: Cutting a 7/24 taper for BT30
« Reply #1 on: August 28, 2018, 08:15:22 AM »
OK I'm a little confused on the taper angle. Some say (half angle) 8.2971 and others say 8.1301 .
« Reply #2 on: August 29, 2018, 08:41:26 AM »
See the attached pic's for dimensions of a BT30 plug gage and spindle.
There is a tolerance on the basic 1.250" dimension. Doubt that you can hold it on your lathe.
Frankly should make a gage to check and refine the taper post turning. BTW, usually they are ground.
Don't use Mach4 lathe but will remark to make sure the code generated is for the mode your using
ie; diameter or radius.
Have fun,
Offline Azalin
  •  189 189
« Reply #3 on: August 01, 2023, 08:36:51 AM »
wow @Rich sorry I missed your response.
« Reply #4 on: August 01, 2023, 02:29:40 PM »
Below is the Gcode to turn a BT30 taper using Mach3.  I wrote this some time back, actually using a spreadsheet to do the calcs and generate the code.  I attach the spreadsheet as well.  It seemed to work as the taper fitted the socket on my Novamill pretty well.
G18 G40 G49 G90 G94 G80
G00 X31.35 Z0.6
G01 X31.35 Z-86.5285714285714
G00 X31.55 Z-86.5285714285714
G00 X31.55 Z0.6
G00 X30.95 Z0.6
G01 X30.95 Z-85.1571428571428
G00 X31.15 Z-85.1571428571428
G00 X31.15 Z0.6
G00 X30.55 Z0.6
G01 X30.55 Z-83.7857142857143
G00 X30.75 Z-83.7857142857143
G00 X30.75 Z0.6
G00 X30.15 Z0.6
G01 X30.15 Z-82.4142857142857
G00 X30.35 Z-82.4142857142857
G00 X30.35 Z0.6
G00 X29.75 Z0.6
G01 X29.75 Z-81.0428571428571
G00 X29.95 Z-81.0428571428571
G00 X29.95 Z0.6
G00 X29.35 Z0.6
G01 X29.35 Z-79.6714285714286
G00 X29.55 Z-79.6714285714286
G00 X29.55 Z0.6
G00 X28.95 Z0.6
G01 X28.95 Z-78.3
G00 X29.15 Z-78.3
G00 X29.15 Z0.6
G00 X28.55 Z0.6
G01 X28.55 Z-76.9285714285714
G00 X28.75 Z-76.9285714285714
G00 X28.75 Z0.6
G00 X28.15 Z0.6
G01 X28.15 Z-75.5571428571429
G00 X28.35 Z-75.5571428571429
G00 X28.35 Z0.6
G00 X27.75 Z0.6
G01 X27.75 Z-74.1857142857143
G00 X27.95 Z-74.1857142857143
G00 X27.95 Z0.6
G00 X27.35 Z0.6
G01 X27.35 Z-72.8142857142857
G00 X27.55 Z-72.8142857142857
G00 X27.55 Z0.6
G00 X26.95 Z0.6
G01 X26.95 Z-71.4428571428572
G00 X27.15 Z-71.4428571428572
G00 X27.15 Z0.6
G00 X26.55 Z0.6
G01 X26.55 Z-70.0714285714286
G00 X26.75 Z-70.0714285714286
G00 X26.75 Z0.6
G00 X26.15 Z0.6
G01 X26.15 Z-68.7
G00 X26.35 Z-68.7
G00 X26.35 Z0.6
G00 X25.75 Z0.6
G01 X25.75 Z-67.3285714285715
G00 X25.95 Z-67.3285714285715
G00 X25.95 Z0.6
G00 X25.35 Z0.6
G01 X25.35 Z-65.9571428571429
G00 X25.55 Z-65.9571428571429
G00 X25.55 Z0.6
G00 X24.95 Z0.6
G01 X24.95 Z-64.5857142857143
G00 X25.15 Z-64.5857142857143
G00 X25.15 Z0.6
G00 X24.55 Z0.6
G01 X24.55 Z-63.2142857142858
G00 X24.75 Z-63.2142857142858
G00 X24.75 Z0.6
G00 X24.15 Z0.6
G01 X24.15 Z-61.8428571428572
G00 X24.35 Z-61.8428571428572
G00 X24.35 Z0.6
G00 X23.75 Z0.6
G01 X23.75 Z-60.4714285714286
G00 X23.95 Z-60.4714285714286
G00 X23.95 Z0.6
G00 X23.35 Z0.6
G01 X23.35 Z-59.1
G00 X23.55 Z-59.1
G00 X23.55 Z0.6
G00 X22.95 Z0.6
G01 X22.95 Z-57.7285714285715
G00 X23.15 Z-57.7285714285715
G00 X23.15 Z0.6
G00 X22.55 Z0.6
G01 X22.55 Z-56.3571428571429
G00 X22.75 Z-56.3571428571429
G00 X22.75 Z0.6
G00 X22.15 Z0.6
G01 X22.15 Z-54.9857142857143
G00 X22.35 Z-54.9857142857143
G00 X22.35 Z0.6
G00 X21.75 Z0.6
G01 X21.75 Z-53.6142857142857
G00 X21.95 Z-53.6142857142857
G00 X21.95 Z0.6
G00 X21.35 Z0.6
G01 X21.35 Z-52.2428571428572
G00 X21.55 Z-52.2428571428572
G00 X21.55 Z0.6
G00 X20.95 Z0.6
G01 X20.95 Z-50.8714285714286
G00 X21.15 Z-50.8714285714286
G00 X21.15 Z0.6
G00 X20.55 Z0.6
G01 X20.55 Z-49.5
G00 X20.75 Z-49.5
G00 X20.75 Z0.6
G00 X20.15 Z0.6
G01 X20.15 Z-48.1285714285714
G00 X20.35 Z-48.1285714285714
G00 X20.35 Z0.6
G00 X19.75 Z0.6
G01 X19.75 Z-46.7571428571429
G00 X19.95 Z-46.7571428571429
G00 X19.95 Z0.6
G00 X19.35 Z0.6
G01 X19.35 Z-45.3857142857143
G00 X19.55 Z-45.3857142857143
G00 X19.55 Z0.6
G00 X18.95 Z0.6
G01 X18.95 Z-44.0142857142857
G00 X19.15 Z-44.0142857142857
G00 X19.15 Z0.6
G00 X18.55 Z0.6
G01 X18.55 Z-42.6428571428572
G00 X18.75 Z-42.6428571428572
G00 X18.75 Z0.6
G00 X18.15 Z0.6
G01 X18.15 Z-41.2714285714286
G00 X18.35 Z-41.2714285714286
G00 X18.35 Z0.6
G00 X17.75 Z0.6
G01 X17.75 Z-39.9
G00 X17.95 Z-39.9
G00 X17.95 Z0.6
G00 X17.633 Z0.6 F15
G01 X17.633 Z-40
G01 X31.75 Z-88.4
G00 X33 Z-88.4
G00 X40 Z0.6
« Reply #5 on: August 03, 2023, 03:20:57 AM »
Was this helpful?
Offline Azalin
  •  189 189
« Reply #6 on: August 03, 2023, 03:22:23 AM »
Yes, John.
Thanks.
« Reply #7 on: August 04, 2023, 03:05:48 AM »
Happy to help.
