Hello Guest it is October 24, 2026, 08:48:03 PM
Author Topic: variable  (Read 14322 times)
Re: variable
« Reply #10 on: July 25, 2018, 01:13:53 AM »
ok thank you
mach 4
can you or sb write code
1-it must work all the time, from the moment the program is started until the program is turned off
2-must read the register
3- multiply by 5, divide by 6
4- save the result to the registry gRegs0/newreg45
In this case
I have an analogue value at the entrance
I want to show this result in a form other than 0-10v
otherwise I will have to interpolate the axes
so I would ask for a script
Re: variable
« Reply #11 on: July 25, 2018, 01:56:18 AM »
yes, that can be done no sweat! The code needs to go it the PLC script.
You can strip some of the extra stuff of the code:
Code: [Select]
local inst=mc.mcGetInstance()
local hreg=mc.mcRegGetHandle(inst,'ESS/Encoder_0')
local regvalue=mc.mcRegGetValueString(hreg)
regvalue=tonumber(regvalue)
regvalue=(regvalue*5)/1.141
regvalue=tostring(regvalue)
hreg=mc.mcRegGetHandle(inst,'gRegs0/newreg45')
mc.mcRegSetValueString(hreg,regvalue)
The PLC script is part of the GUI root viewed and edited in Edit Screen Mode.
Re: variable
« Reply #12 on: July 25, 2018, 04:07:25 AM »
thank you my friend
