Hello Guest it is November 02, 2026, 10:59:26 PM
Author Topic: Emco 120P  (Read 9844 times)
Emco 120P
« on: July 24, 2007, 07:31:45 AM »
Has anyone converted a 120 to Mach 3?
Bob
Offline Monty
  •  116 116
Re: Emco 120P
« Reply #1 on: July 24, 2007, 08:46:32 AM »
If it's anything like my emco 140 it will need a whole new control to work with mach.
Does it have 5 phase steppers?
Is the main spindle a DC motor and what HP is it?
I am using the existing 5 phase steppers. The only drives I know of that will work are Vexta drives. They are on ebay for around $100/axis. If you have the german motors you will have to do some sluething to find the right part# for the vexta drive to work with it. I have some documentation that may be of some use.
The alternative is to replace the motors with more modern stuff. Mine were brand new, so I elected to use them.
The spindle drive is a bit more of a problem. Mine is a 7.5 hp DC drive, but it is a 400V motor. So I am running it at 250V. I will only get about 4hp cont. 5hp peak this way, but that is enough for my needs.
I am currently putting the thing together.
I'll help if I can.
Monty
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: Emco 120P
« Reply #2 on: July 25, 2007, 12:41:22 PM »
Check out Digital Machinist, a publication by Home Shop Machinist & Machinist Workshop.  They had an article on converting an EMCO machine and it may apply to yours also.  It was just a matter of clipping a latching type IC off the board and installing some jumpers, no extra drivers to buy.  I just read it yesterday.
