Hello Guest it is November 13, 2026, 03:05:11 PM
Author Topic: Knocking X axes, whats going on ??  (Read 19503 times)
Re: Knocking X axes, whats going on ??
« Reply #10 on: July 17, 2018, 06:24:38 AM »
I would suggest you have a look at the pulse stream with an o'scope. You may find that there is ringing on the generated pulse stream. Usually it would be constant but it can be random. You need to get rid of it at the source and can be difficult to remove.
 The ringing will just carry through to other electronic devices if you don't eliminate it.
« Last Edit: July 17, 2018, 06:27:28 AM by RICH »
« Reply #11 on: July 17, 2018, 07:22:44 AM »
Hey Rich
I know there is the possibility of noise being produced unfortunately i don't have a scope to test it with
but why would it do it with Mach 3 and not with Mach 4 ???
« Reply #12 on: July 17, 2018, 05:11:16 PM »
Have no answer to that question. It would be interesting to see the signal output from both since it's the same computer and
and physical pp port.
« Reply #13 on: July 18, 2018, 05:08:13 AM »
Yes you are right it would be interesting to see
I just orders a ESS board and going through a pile of extra parts i found a American made 48V power supply, and 4 gecko drives.
That should solve lots of my problems if not all of them :)
