Hello Guest it is October 24, 2026, 05:30:01 PM
Author Topic: Problem running XY Offset Calibration Probe  (Read 20359 times)
Re: Problem running XY Offset Calibration Probe
« Reply #10 on: July 14, 2018, 01:44:42 PM »
I use an ESS and I do have a little filtering on the probe. I also have a 500pF capacitor on the input pin.
While its true you don't want excessive filtering which would slow the 'probe strike event' modest filtering is fine.
« Reply #11 on: July 14, 2018, 02:33:31 PM »
Thank you Fledermaus.  I'll try your routine if my other efforts prove to be unsuccessful.  The default size of the bore gauge is 1 inch for this XY Offset Calibration.  My bore gauge is nearly 2 inches, and I'm wondering if that may be part of the issue the amount of time it takes to travel that larger distance before the probe strike.
I'm out of town, so once I return home, I will try a faster approach speed first, then try some debounce if the faster approach speed doesn't resolve it.
So grateful for all the responses.  Thanks to all for your help.
« Reply #12 on: July 14, 2018, 02:39:14 PM »
The default is just an arbitrary number. In my system it would have been 1mm! Seriously, the diameter can be any size you choose, and the time it takes doesn't detract from correct operation.
Allan
« Reply #13 on: July 14, 2018, 03:08:41 PM »
That's good to know.  That's how I would expect it to work, but I'm still new to this, and still learning.  Thanks again.
« Reply #14 on: July 16, 2018, 05:06:16 AM »
I added 500 to the noise filtering of my 3DProbe pin and went from 20 to 30 approach speed in the probing, and it worked!  Thanks to all who contributed.  Now, I can move on to more productive things.
Offline Stuart
  •  311 311
« Reply #15 on: July 16, 2018, 08:42:40 AM »
Glad to be of help
« Reply #16 on: July 16, 2018, 03:01:39 PM »
Pleased  you got it sorted.
Allan
