Hello Guest it is October 25, 2026, 05:35:57 AM
Author Topic: "Jog inc" is under ouput signals so how to trigger inc Jog step in mach 4??  (Read 16226 times)
ess only had like 15 may be slightly off on #s
thats incorrect, the ESS has three ports for 48 inputs/outputs.
from the Warp9 website relating to the ESS:
•Parallel Port #1: 12 Outputs, 5 Inputs
•Parallel Port #2: 4 Dedicated Outputs, 5 Dedicated Inputs, and 8 block assignable as input or output
•Parallel Port #3: 4 Dedicated Outputs, 5 Dedicated Inputs, and 8 block assignable as input or output
Thus my previous post is wrong, there are 51 inputs/outputs.
is a button that cycles through the jog increments, is that what you want to do?
