Hello Guest it is November 06, 2026, 02:10:50 PM
Author Topic: Mach 3 Modbus TCP with Siemens Logo!8  (Read 25450 times)
« on: June 28, 2018, 12:45:38 PM »
Hello,
forgive my bad English
I want to connect Mach3 with a Siemens Logo!8 (which ModbusTCP should be able). I want to switch the spindle-frequency-inverter on and off (relay) via Modbus TCP and set the speed via an analog output 0-10VDC. I'm honest, I don't know exactly what to put where. Tried everything but didn't get it to run. Has anybody got that combination to go?
Re: Mach 3 Modbus TCP with Siemens Logo!8
« Reply #1 on: June 28, 2018, 04:01:32 PM »
that pic is of the PLC program....you haven't got that far yet.
You need to program Mach to talk over TC/IP Modbus BEFORE you start worrying about programming the PLC.
« Reply #2 on: June 29, 2018, 12:50:26 PM »
excuse
I activated Modbus TCP in Mach3 and tried to set.
I haven't figured out what I've got wrong yet.
« Reply #3 on: June 29, 2018, 12:55:44 PM »
more pictures. i have not been able to add them at once
Offline TPS
  •  2,627 2,627
« Reply #4 on: June 30, 2018, 02:55:15 AM »
Hello Manfred,
you will also have to do some Brain in Mach to write to the modbus.
Thomas
