Hello Guest it is November 22, 2026, 02:24:20 PM
Author Topic: another sub-routine problem  (Read 10081 times)
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« on: July 21, 2007, 06:57:45 AM »
I am running up a g-code program, which involves cutting a shape out of steel, and then machine various rebates in it. The rebates are mostly all the same.
The g-code for the shape is in a subroutine which I call with M98 - and it closes on M99 and returns - the program carries on.
The second rountine is called with the M98 - but when it show up in the g-code box on Mach3 mill, the M99 return code is missing and so the program stops when it gets to there.
M99 is present on all the subroutines in the subroutines folder - but when this one is loaded, it disappears.
Can anybody help, please - I am at a loss to understand this.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: another sub-routine problem
« Reply #1 on: July 21, 2007, 07:18:50 AM »
Hi, Jimpinder
Check your second M99 has a Line feed or % sighn after it.
M99
Hope this is It, Chip
Offline jimpinder
  •  1,232 1,232
« Reply #2 on: July 21, 2007, 09:34:33 AM »
I put a % sign after it and it worked a treat - thanks a lot
Jim
