Hello Guest it is October 01, 2026, 08:54:10 AM
Author Topic: Save Z - Beginner - To many options - Simple but not for me  (Read 12227 times)
Hi
I have been generated some gcodes from Vetric where it demands the Save Z settings and Home start position x,y, z.
My autotool macro have also an save Z setting:
ZMove = 30.00 'Total lenght of Probe to move before Stop or no Contact Made.
ZOffset = 25.00 ' Plate Hight
ZSal = ZOffset + 2.00 '+ Free Hight, Will possition the Proble 2 MM over the Material.
Mach3 config also have a save Z setting.
So now am I confused.
How should the output be:
Vetric
Save Z = ?
z1 = Clearance = ?
z2 = Plunge = ?
Home start x=0,y=0,Z=?
Mach3
Config - should I also use the same save Z settings in here ?
In Mach3:
What should the DRO be at:
X=0
Y=0
Z=???
Hope you can help me...
« Last Edit: June 06, 2018, 07:23:08 AM by jokerper »
Re: Save Z - Beginner - To many options - Simple but not for me
« Reply #1 on: June 08, 2018, 03:26:00 AM »
Why do I not get any replys. What am I been doing wrong.
Atleast give me a hint. Dont let me be a cliffhanger here.
  •  9,374 9,374
« Reply #2 on: June 08, 2018, 03:51:21 AM »
You are not doing anything wrong you just need to give it more time - many do not visit the forum on a daily basis and many, like me, just don't have a definitive answer.
Offline ZASto
  •  434 434
« Reply #3 on: June 08, 2018, 04:55:10 AM »
It is not "saVe Z" but "saFe Z".
In Vectric:
Z1 Clearance is height above material Zero (top of material) for rapid movement (G0) to avoid any clamping of your material.
Z2 Plunge is height above material to which your tool will be plunged at rapid speed (G0) before switching to programmed plunge speed (G1).
For Safe Z in Mach3, you should do some reading (Mach3 manual, no link at the moment).
And please, take look at the attached picture. If it does not make all clear, then sorry  ;D
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #4 on: June 08, 2018, 07:27:55 AM »
If you have a Z axis Home switch, then in Mach3 I would set it to machine coordinates, and a small negative number, like -1.
If you don't have a Z home switch, then I would disable Safe Z in Mach3.
« Reply #5 on: June 08, 2018, 11:59:37 AM »
In Vectric:
Can I ask you about the setting "Position model Gap above material" 1mm
I think I have been getting into some good settings now.
Code: [Select]
ZMove = 30,00 'Total længde af Probe at flytte før Stop eller ingen kontakt lavet.
ZOffset = 25,00 '
Pladhøjde ZSal = ZOffset + 2,00' + Gratis Højde, vil give den mulige 2 MM over materialet.
Mach3 config har også en gemt Z-indstilling.
Så nu er jeg forvirret.
Hvordan skal output være:
Vetric
Save Z =2
z1 = Clearance = 2
z2 = Stoppe =?
Startside x = 0, y = 0, Z =4
Mach3
Config - skal jeg også bruge de samme gemme Z indstillinger her?
I disabled Safe Z in mach3
I Mach3:
Hvad skal DRO være på:
X = 0
Y = 0
Z = 4
I think it works for me.
Offline ZASto
  •  434 434
« Reply #6 on: June 08, 2018, 04:42:52 PM »
The surface of a wood that I've been cutting in 2.5D was uneven, and since there was a lot of material on the back side, the whole model was "sunk" for 1mm.
