Hello Guest it is November 22, 2026, 01:39:45 AM
Author Topic: MACH3 fails after some updates of win7  (Read 15350 times)
« on: May 01, 2018, 05:08:15 AM »
MACH3 does a restart of windows. Even the Drivertest does a restart. This happens for a few weeks now.  After I reinstalled win7, everthing was ok again, but after some updates it fails again. Is this a known problem? What to do
  •  9,378 9,378
Re: MACH3 fails after some updates of win7
« Reply #1 on: May 01, 2018, 07:56:08 AM »
« Reply #2 on: May 01, 2018, 09:47:03 AM »
Tweakie, thank you. It solved  the problem
« Reply #3 on: May 01, 2018, 01:45:36 PM »
Thanks a lot Tweakie :) My issue got fixed upon uninstall and reinstallation of Mach3..
« Reply #4 on: May 02, 2018, 10:03:35 AM »
As I need to be always connected , how can I avoid that this updat comes again and again.....
Reinstallation of MACH3 didn't help.
I cannot believe that I always have to uninstall this update before I can use MACH3 again.
  •  9,378 9,378
« Reply #5 on: May 02, 2018, 10:39:04 AM »
Your machine PC needs to be a 'dedicated machine PC' which is not connected to the internet, does not run other software in the background and does not receive updates.
« Reply #6 on: May 02, 2018, 11:14:40 AM »
You also have the option to upgrade to an external motion controller. The issue has been with Mach3 and the parallel port and the recent Windows 7 updates, but no problems have been reported with external motion controllers. Just some food for thought!
-Bryanna
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
