Hello Guest it is October 24, 2026, 10:20:17 PM
Author Topic: Mach 4 macro for setting current fixture offset to zero?  (Read 23306 times)
Offline Rimmel
  •  284 284
Re: Mach 4 macro for setting current fixture offset to zero?
« Reply #10 on: August 27, 2024, 01:23:01 PM »
Hey Jorgenbli,
I can't find the VAR to change the Z Position.  There are registers to get the current Z and Machine Coordinate Z.  When I try to write to them they don't change/update anything.
There is a command to change the Z Axis DRO position.    This does update the VARS relating to Current Z Position.
mc.mcAxisSetPos(inst, 2, 5.5) --(inst, Axis#, New Position)
Or make it update to a variable.
local NewZPos = 5.5
mc.mcAxisSetPos(inst, 2, NewZPos)
Just needed this - thank you (again)
Offline smurph
  •  1,575 1,575
« Reply #11 on: August 29, 2024, 02:20:22 PM »
You can set the tool offset with G10 L1 and the fixture offsets with G10 L2 as well.
Steve
