Hello Guest it is October 24, 2026, 07:32:47 PM
Author Topic: A Aixs Brake  (Read 18292 times)
Re: A Aixs Brake
« Reply #10 on: January 28, 2019, 11:09:11 AM »
Any luck in getting mc.mcAxisIsStill working?  I am having the same problem that when running gcode it returns positive no matter what the axis is doing.
David
Re: A Aixs Brake
« Reply #11 on: January 28, 2019, 11:32:01 AM »
I haven't tested this any further, maybe Brett or Steve can chime in on this one.
I found out how to get Fusion to post an M Command to engage and disengage the A Axis Brake for 3+1 or simultaneous 4th axis machining, so I don't need the mc.mcAxisIsStill right now.
I read the thread you just started,
It was suggested in this thread that you may be able to get an output from the drive to use.  I was able to get an output off the drives I was using; but then I ran into the delay time needed to release the brake completely, so I was unable to use it effectively.
« Last Edit: January 28, 2019, 11:34:44 AM by Cbyrdtopper »
Chad Byrd
Re: A Aixs Brake
« Reply #12 on: January 28, 2019, 04:56:28 PM »
Hey thanks for the reply,
I actually need something from Mach4 to initialize a check on the motor.  Essentially I am trying to create an extra level of safety in the case of a wire fault or any other reason signals might not get to the motors. I am using clearpath motors, which will know if they are out of position, but if a signal fails to reach them, they won't know they missed anything.
I had a strange incident when Mach4 stopped sending step and direction signals intermittently when jogging.  The whole program was behaving erratically and was fine after a restart, but it was enough to make me want to create a way for the clearpath motor to verify that it is moving when Mach thinks it is.
Re: A Aixs Brake
« Reply #13 on: January 28, 2019, 05:24:26 PM »
It sounds like you want communication from the drive to Mach.   You will need some sort of output from the motor drive to do that
Chad Byrd
Re: A Aixs Brake
« Reply #14 on: January 28, 2019, 07:12:51 PM »
Yeah, that's no problem for the Clearpath motors.  They have a pretty wide range of output options to choose from including one that is high whenever it is moving.  I just need mach4 to know when to look for it, and to trigger an estop if it doesn't see it.  That's why I was thinking mc.mcAxisIsStill would be perfect.  I could just put something into the plc script that says that every time the axis is moving, if a particular input is low then perform an estop.
Not sure if that is all correct, but it might be a moot point if I can't find a way to query if an axis is moving or not.
Re: A Aixs Brake
« Reply #15 on: January 29, 2019, 10:32:30 AM »
If you want to know if an axis is moving or not get its velocity.
velocity, rc = mc.mcAxisGetVel(
   number mInst,
   number axisId)
Description:
Get the velocity of an axis in user units per min.
Re: A Aixs Brake
« Reply #16 on: January 29, 2019, 01:39:10 PM »
Ha! I should have thought of that!
Works Perfectly.  Thank you so much!!!!
Re: A Aixs Brake
« Reply #17 on: January 29, 2019, 05:39:28 PM »
No problem, glad it helped.
