Hello Guest it is November 22, 2026, 09:18:08 PM
Author Topic: Low voltage on stepper port issues  (Read 25119 times)
Re: Low voltage on stepper port issues
« Reply #10 on: March 24, 2018, 09:32:53 AM »
I'm bad with these terms, What doe BoB stand for?
Offline TPS
  •  2,627 2,627
« Reply #11 on: March 24, 2018, 09:33:41 AM »
breakoutboard
« Reply #12 on: March 24, 2018, 09:51:03 AM »
There are no other ways to do the wires to get it to work that i know of.
But is there any way to control the output from the mach3 program, or something else we could do to troubleshoot it?
Offline TPS
  •  2,627 2,627
« Reply #13 on: March 24, 2018, 09:57:37 AM »
you can check the direct signals from the parallel port (pin 6/7 from 25pole Sub D), with oszilloscope.
« Reply #14 on: March 24, 2018, 10:00:05 AM »
I'll keep that in mind and try it as soon as I can.
Thanks.
Though, could it be the parallel port that is doing this? To get lower voltage at the card.
  •  9,378 9,378
« Reply #15 on: March 25, 2018, 01:00:20 AM »
You can check if it is the parallel port that has the problem...
Note the two pins that you are using for Z axis.
In Ports and Pins / Motor Outputs configuration swap X axis pins for Z axis pins.
If Z axis now works and X axis does not work then it is the LPT parallel port that needs replacing.
If Z axis still does not work but X axis does then it is your driver card that needs replacing.
Offline TPS
  •  2,627 2,627
« Reply #16 on: March 25, 2018, 03:55:19 AM »
not realy,
because for example pin 6/7 will stll be connected to the same optocouples of the board (physicaly).
to do this test you have to swap Pins at the 25pol. Sub D (LPT Card or board side does not matter).
  •  9,378 9,378
« Reply #17 on: March 25, 2018, 04:15:22 AM »
You're right TPS, the physical pin connections have to be changed, please ignore my earlier post.
« Reply #18 on: March 26, 2018, 08:20:54 AM »
Measuring the ports on the PC gives this result.
This is directly at the PC no cables in between.
pin2  4,79v
pin3  4,79v
pin4  4,79v
pin5  4,79v
pin6  3,1v
pin7 -0,249v
pin 2 is step for X
pin 3 is dir for X
pin 4 is step for Y
pin 5 is dir for Y
pin 6 is step for Z
pin 7 is dir for Z
« Reply #19 on: April 01, 2018, 01:46:22 AM »
Check the pins at the computer first. If OK at the computer, check at the end of the cable.
I just went through the same thing and discovered it was a bad cable.
