Hello Guest it is November 23, 2026, 09:13:25 PM
Author Topic: Adding outputs controlled by custom buttons  (Read 10501 times)
« on: March 17, 2018, 08:33:27 AM »
My first post here.
I have built a  Plasma table from scratch which works well.
I am now adding some extra functionality to it.
It uses a UC400ETH notion controller.
I wish to add a custom button to my mach screen.
I am using the spindle relay on my breakout board to trigger my plasma, I would like that when the custom button is clicked another output operates whenever the spindle does.
Reason for this,  I have mounted a visible laser to the plasma torch and i want the laser to operate instead of the plasma cutter, giving a visual 'Dry run'.
I know I can do this with a mechanical switch but I would like to use Mach3 to control it.
I have used Machscreen to add a button and then I assume I need to write a brain or some VB to complete the task.
If someone could point me in the right direction I'd very much appreciate it.
Offline TPS
  •  2,627 2,627
Re: Adding outputs controlled by custom buttons
« Reply #1 on: March 17, 2018, 09:16:19 AM »
declare Standard code of your button as 34 (execute Basic stript)
then einter this vb code to script
If IsActive(OUTPUT1) Then
  DeactivateSignal(OUTPUT1)
Else
  ActivateSignal(OUTPUT1)
End If
« Reply #2 on: March 17, 2018, 10:24:00 AM »
Thanks for the prompt reply.
« Reply #3 on: March 18, 2018, 12:22:52 PM »
I tried this with some success, I could turn  output 3 on but it didn't turn off again.
Output 1 and 6 did nothing.
What am I missing?
Offline TPS
  •  2,627 2,627
« Reply #4 on: March 19, 2018, 04:12:38 AM »
sorry Little mistake, right code:
If IsOutputActive(OUTPUT1) Then
Else
End If
it will only work for Outputs witch are enabled in Config -> Ports&Pins -> Outputs
« Reply #5 on: March 19, 2018, 07:02:39 AM »
Thanks Again
