Hello Guest it is October 21, 2026, 06:22:31 PM
Author Topic: Motors keep adding steps  (Read 19281 times)
Re: Motors keep adding steps
« Reply #10 on: March 11, 2018, 10:41:12 PM »
I am not at building circuit boards.  I am completely new to CNC.
« Reply #11 on: March 11, 2018, 10:46:54 PM »
OK then you are going to have to replace probably the BoB to make it work.
Do you have manufacturers documentation for both the BoB you already have and your stepper drivers?
I'm hoping there might be a simple solution.
If your budget is tight then you may have to consider making an amplifier solution....one IC...$4.00 or so
and 2 sq inch of vero board...not that hard.
« Reply #12 on: March 11, 2018, 11:10:56 PM »
Thanks, I'll do some research and see what I think will work best
  •  9,374 9,374
« Reply #13 on: March 12, 2018, 01:32:18 AM »
The simplest solution may be to just obtain a new PCI parallel port card that outputs 5Volt TTL signals. This thread may help https://www.machsupport.com/forum/index.php/topic,34848.0.html
