Hello Guest it is October 22, 2026, 03:01:46 PM
Author Topic: LOST BUT NOT BEATEN  (Read 21691 times)
Re: LOST BUT NOT BEATEN
« Reply #10 on: February 14, 2018, 02:33:22 PM »
ger21,
NO IT DOES NOT
« Reply #11 on: February 14, 2018, 03:16:06 PM »
Then it likely is an issue with your g-code.
« Reply #12 on: February 15, 2018, 05:46:30 AM »
As a follow up. I reviewed the G code last night and it is correct. All of the moves in the G code goes exactly where it should. So Im unsure of what to check now. The tool path on the screen matches what is being cut and that is incorrect.
« Reply #13 on: February 15, 2018, 06:35:42 AM »
Mach3 should always be displaying the g-code correctly, unless there's an error in the g-code. The one exception would be IJ mode, which I wouldn't expect to be an issue in this case?
Do you have a valid Mach3 license installed?
« Reply #14 on: February 15, 2018, 09:04:50 AM »
YES
« Reply #15 on: February 18, 2018, 07:46:39 AM »
Pretty please post the G-code for us to review.
Sometimes it is the unknown stuff that bites you  in a tender spot.
Mike
  •  9,374 9,374
« Reply #16 on: February 19, 2018, 12:39:15 AM »
Hi Forbri40,
I have sent you a PM.
