Hello Guest it is November 13, 2026, 01:17:45 PM
Author Topic: I Need a macro written will pay.  (Read 39719 times)
Offline TPS
  •  2,627 2,627
Re: I Need a macro written will pay.
« Reply #10 on: February 01, 2018, 01:33:09 PM »
Tony,
still got not Response from Keyence for the manual.
i think i will have a phone call tomorrow.
Your "project" with this laser sound's like an new "Challenge", but if you want i am
in this Challenge.
let's start (but when i think about it, we started allready ;))
Thomas
Offline comet
  •  338 338
« Reply #11 on: February 01, 2018, 01:57:52 PM »
Thats great Thomas,
   I dont know if this has even been done before. could be new ground were treading on.
Are you proficiant with software writing? if not then we will need someone else for sure.
  ill try and download the full manuals as well although i cant promise ill understand them!
Regards
  Tony
« Reply #12 on: February 01, 2018, 02:07:40 PM »
Interesting project Tony, I'll be following along intently.  :)
There is a bit of info in this catalog, in case you don't have it.
Russ
Offline comet
  •  338 338
« Reply #13 on: February 01, 2018, 03:10:22 PM »
cheers OL yes ive tried using a laser proxy sensor mounted on a high speed z axis but although succesfull and accurate, it is still a time consuming process.
hopefully we can get to grips with the hardware/software in this method because i feel that the bed of nails method of scanning/digitizing is superior when it comes to accuracy to other
systems, certainly systems that are within the scope of the home machinist .
Regards
Tony
« Reply #14 on: February 01, 2018, 05:41:13 PM »
If your interested in trying it with Mach4 I posted a teach file script for it not too long ago that may get you almost where you want to be. Would just need to get the register value you will be using for the analog input from the laser instead of Z axis position And automate some moves between readings I think.
Offline comet
  •  338 338
« Reply #15 on: February 01, 2018, 06:12:12 PM »
Chaotcone , yes I would be but that is the sort of stuff that is presently beyond me, but hopefully not for others.Do you have a link?
Tony
« Reply #16 on: February 01, 2018, 07:34:40 PM »
I don't have a link handy but you can search this forum for Mach 4 Teach File and find it pretty quick I think.
Offline comet
  •  338 338
« Reply #17 on: February 01, 2018, 08:51:57 PM »
Ill have a look, but on reflection I dont think i want to be messing about with mach4 right now, as well as trying to get this project working, atleast if I dont have to.
Offline comet
  •  338 338
« Reply #18 on: February 01, 2018, 09:03:09 PM »
Found the laser manual ive attached it
Offline TPS
  •  2,627 2,627
« Reply #19 on: February 02, 2018, 02:17:32 AM »
Hello Tony,
according to the Manuals i would connect the laser like this (if the UC300 has a external 5V supply)
il1000 Brown uc300 anaolg plug pin1 -> 12V
il1000 Blue uc300 anaolg plug pin2 -> 0V
il1000 orange uc300 anaolg plug pin3 -> analog Input1
il1000 shield uc300 anaolg plug pin5 -> gnd
(if the UC300 has no external 5V supply)
il1000 Brown external power supply -> 10-30VDC
il1000 Blue external power supply -> 0V
and if i understand UC300 Manual we should get a value in OEMDRO(1000)
but you have to do this from the il1000 Manual:
"3-1 Operation When the Power is Turned on for the First Time" (page 3-2)
"3-3 Initial Reset (Initialize)" (page 3-8)
as well.
Thomas
