Hello Guest it is September 14, 2026, 12:19:01 AM
Author Topic: Mach Config, General, Control Mode  (Read 5960 times)
« on: January 29, 2018, 09:13:48 PM »
The manual does not show or describe the Control Mode selection options.
The General tab in the current release is a bit different and has a selection for the Control Mode.
What is the significance of the Control Mode dialog ? The stock Lathe profile seems to open in dia. mode but the dialog says MILL.
 And If I change it to lathe, diameter mode, popup says must restart. Shut down (task mgr as usual) then M4 refuses to start. That part could be my lame laptop, but what about the dialog ?
Re: Mach Config, General, Control Mode
« Reply #1 on: January 30, 2018, 09:27:21 AM »
ok, I can't repeat this on a better pc so please disregard.
thanks,
Russ
