Hello Guest it is November 23, 2026, 01:09:48 AM
Author Topic: Edit X Position (newb, be gentle)  (Read 19876 times)
Re: Edit X Position (newb, be gentle)
« Reply #10 on: January 15, 2018, 12:15:46 PM »
That would be great Mike, please do !
I'm especially curious as to how well your setup performs the pullout at the end of the thread when threading a continuous OD shaft with no relief groove at the termination point.
Standing by ......
Thanks Mike,
Russ  :)
« Reply #11 on: January 15, 2018, 12:28:06 PM »
   It is designed totally different from Mach3, implementing Fanuc gcode,  .............
RT
Do you know if it uses Fanuc G76 ... or G78  ? ? or ? ? for the threading ?
Thanks RT,
Russ
