Hello Guest it is October 23, 2026, 09:50:37 AM
Author Topic: Setting Motor Counts Per Unit in macro  (Read 44729 times)
Re: Setting Motor Counts Per Unit in macro
« Reply #40 on: December 07, 2018, 12:25:53 PM »
there is an API for that, but I'm not sure that it was intended for use on the fly, that is to say I thought it was for use in plugins
where a parameter, in this case 'steps per unit', were set for a device and then left alone.
LUA Syntax:
rc = mc.mcMotorSetCountsPerUnit(
      number mInst,
      number motorId,
      number counts)
Description:
Set the counts per native machine setup units.
« Reply #41 on: December 07, 2018, 12:53:02 PM »
This may work out well for me because I am not cutting tapers. I would set the diameter DRO before I ran the job Just as I do in Mach3. I will have to play with this a little. It may not be soon. Maybe Maury could work with this on tapers.
Thank you Graig.
