Hello
Guest
it is
October 21, 2026, 03:49:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Are the G Codes at the top right of the main screen all the active codes?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Are the G Codes at the top right of the main screen all the active codes? (Read 9353 times)
Planobilly
36
on:
December 29, 2017, 12:49:14 PM »
I assume the codes at the top right of the main screen are the ones that are active. Correct?
Why would g97 and g94 be active for a mill program? I assume g97 and g94 are for turning applications.
Billy
Logged
ger21
6,295
Re: Are the G Codes at the top right of the main screen all the active codes?
Reply #1 on:
December 29, 2017, 06:07:35 PM »
G94 would be the standard mode for Mill. Alternatively, you could use G93.
I don't know what G97 is, as it's not listed in either the Mach3 Mill or Lathe manuals.
Logged
Tweakie.CNC
9,374
Super Kitty
Reply #2 on:
December 30, 2017, 01:11:01 AM »
Just in case anyone is curious about the G97…
Constant Surface Speed never really worked correctly in Mach3 and it’s implementation was eventually discontinued. Having the G97 active ensures the spindle will be operating in RPM mode.
Graham Waterworth describes the relevant commands in this thread;
http://www.machsupport.com/forum/index.php/topic,5494.msg37162.html#msg37162
Logged
Print
Pages:
1
Go Up
« previous
next »
