Hello Guest it is November 12, 2026, 12:05:26 PM
Poll
protel pcb Drill file problem with mach2 ?
mach2
0 (0%)
mach2
0 (0%)
Total Members Voted: 0
Author Topic: protel pcb Drill file problem with mach2 ?  (Read 11800 times)
« on: July 05, 2007, 03:41:21 PM »
Hello All .
Has anyone used the .txt or .drl files generated by protel to drive whit MACH2?
someone help me with some hints on how to convert the protel .txt or .drl files to a useable file type ?
Best regards.
reza
vmax549
Re: protel pcb Drill file problem with mach2 ?
« Reply #1 on: July 07, 2007, 10:34:18 AM »
Post an example of the code. (;-) TP
« Reply #2 on: July 08, 2007, 04:40:30 AM »
hi
« Last Edit: July 08, 2007, 04:49:59 AM by NASR »
« Reply #3 on: July 08, 2007, 04:45:20 AM »
hi
This is  a example of protel pcb txt & drl  Excellon  format.
M71
M48
T1F00S00C0.030
T01
X00079Y00039
X00512
X00906
X01299
Y00512
X00906
X00512
X00079
Y01024
X00512
X00906
X01299
X01732
Y00512
Y00039
M30
regards.
vmax549
« Reply #4 on: July 08, 2007, 10:33:37 AM »
I beleive at one time ART was working on bringing in the drill files through LCAM. The code is very similar to GCODE drilling cycles. SHould not be too difficult. Sit down with a list of the commands from the drill file and alist of g/m codes and compare the too. YOu may be able to convert it yourself. (;-) TP
