Hello Guest it is September 17, 2026, 12:47:42 AM
Author Topic: UC400ETH  (Read 21962 times)
Re: UC400ETH
« Reply #10 on: December 26, 2017, 06:35:41 AM »
The 400ETH has two ports. It is pretty much mandatory that pins 2-9 of port 1 are outputs, for your motors. However you can with port 2 change pins
2-9 from outputs to inputs. Note you can assign them as inputs OR outputs, not half and half.
This is incorrect.
Both ports on the UC400ETH have 12 outputs, and 5 inputs, and can not be configured differently.
Re: UC400ETH
« Reply #11 on: December 26, 2017, 07:00:55 AM »
Its a mute point anyway as I will not be changing the configuration. As I have tried to point out this is not my first rodeo I have owned other CNC machines over the past 15 years.   This is my first Mach3 one however that is why I am here. Thanks.
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
