Hello Guest it is July 17, 2025, 09:23:34 AM
Author Topic: simple numeric keyboard for input in DRO  (Read 16741 times)
Offline TPS
  •  2,601 2,601
« on: December 22, 2017, 01:25:36 PM »
Hello,
here a simple solution with "on board" possibilities (VB script) to do Inputs to DRO (touch Screen).
put the following code into a macro in your macrofolder:
Code: [Select]
Global value As String
'TPS 01.12.2017
'numerische Eingabe
Function NumericKeyboard(ByVal DRONum as Integer) As Double
Dim title as String
value = GetOemDRO(DRONum)
title = Header
Begin Dialog UserDialog1 60,60, 105, 180, "Eingabe:"  , .Enable
PushButton 10, 10, 25, 25, "7", .but7
PushButton 40, 10, 25, 25, "8", .but8
PushButton 70, 10, 25, 25, "9", .but9
PushButton 10, 40, 25, 25, "4", .but4
PushButton 40, 40, 25, 25, "5", .but5
PushButton 70, 40, 25, 25, "6", .but6
PushButton 10, 70, 25, 25, "1", .but1
PushButton 40, 70, 25, 25, "2", .but2
PushButton 70, 70, 25, 25, "3", .but3
PushButton 10, 100, 25, 25, ".", .butD
PushButton 40, 100, 25, 25, "0", .but0
PushButton 70, 100, 25, 25, "<-", .butB
TextBox 10, 130, 85, 18, .FText
PushButton 10, 155, 40, 21,"OK", .OK
CancelButton 55, 155, 40, 21
End Dialog
Dim Dlg1 As UserDialog1
Dlg1.FText = CStr(value)
x = Dialog( Dlg1 )
NumericKeyboard = CDbl(Dlg1.FText)
SetOEMDro(DRONum,CDbl(Dlg1.FText))
End Function
Function Enable( ControlID$, Action%, SuppValue%)
Select Case Action%
Case 1
Case 2 'Button wurde gerückt
If ControlID$ = "but0" Then
value = CStr(value) + "0"
DlgText "FText", CStr(value)
Enable =1
End If
If ControlID$ = "but1" Then
value = CStr(value) + "1"
Enable =1
End If
If ControlID$ = "but2" Then
value = CStr(value) + "2"
Enable =1
End If
If ControlID$ = "but3" Then
value = CStr(value) + "3"
Enable =1
End If
If ControlID$ = "but4" Then
value = CStr(value) + "4"
Enable =1
End If
If ControlID$ = "but5" Then
value = CStr(value) + "5"
Enable =1
End If
If ControlID$ = "but6" Then
value = CStr(value) + "6"
Enable =1
End If
If ControlID$ = "but7" Then
value = CStr(value) + "7"
Enable =1
End If
If ControlID$ = "but8" Then
value = CStr(value) + "8"
Enable =1
End If
If ControlID$ = "but9" Then
value = CStr(value) + "9"
Enable =1
End If
If ControlID$ = "butD" Then
   If InStr(1,value,".") = 0 Then
value = CStr(value) + "."
Enable =1
   End If
End If
If ControlID$ = "butB" Then
value = Left(value,Len(value)-1)
Enable =1
End If
If ControlID$ = "OK" Then
Enable = -1
End If
Case 3 'Text verändert
'MsgBox Dlg1.FText
Case Else
End Select
'Wert zurückgeben
If Enable = -1 Then
Enable = value
End If
End Function
ok lets say you put into C:\mach3\macros\yourprofile\numerickeyboard.m1s
if you put following code into a transparent button over the a-axis dro
the code do edit x-axis would be:
Code: [Select]
Sub Main
call NumericKeyboard(800)
End Sub
#Expand <\..\..\macros\yourprofile\numerickeyboard>
the number is the OEMDro you want to edit.
Regards Thomas
Re: simple numeric keyboard for input in DRO
« Reply #1 on: February 02, 2018, 11:30:50 AM »
Well isn't that nifty !
I'll save this in the event I ever get a touch screen set-up on one of my machines.
Very cool !
Thanks for the contribution Thomas.
Much appreciated,
Russ
« Reply #2 on: May 18, 2023, 03:39:38 PM »
Good evening
i installed above the dro ,transparent button,
"simple numeric keyboard" and everything works perfectly
I would like to place it above "MDI" and add the following keys
" X,Y,Z,A,F,SPACE " , I don't know if it's feasible, since it's not
Is there anyone in my capacity who can help me?
as long as it's possible, thanks to anyone who can help me.
Greetings
Offline TPS
  •  2,601 2,601
« Reply #3 on: May 20, 2023, 10:14:11 AM »
not tested
Code: [Select]
'TPS 01.12.2017
'numerische Eingabe
Function NumericKeyboard(ByVal DRONum As Integer) As Double
Dim title As String
'value = GetOemDRO(DRONum)
title = Header
Begin Dialog UserDialog1 60,60, 195, 180, "Input:"  , .Enable
PushButton 100, 10, 25, 25, "X", .butX
PushButton 100, 40, 25, 25, "Y", .butY
PushButton 100, 70, 25, 25, "Z", .butZ
PushButton 100, 100, 25, 25, "A", .butA
PushButton 130, 10, 25, 25, "F", .butF
PushButton 130, 40, 25, 25, "S", .butS
PushButton 130, 70, 25, 25, "M", .butM
PushButton 130, 100, 25, 25, "Sp", .butSp
PushButton 160, 10, 25, 25, "G", .butG
TextBox 10, 130, 175, 18, .FText
End Dialog
'Dlg1.FText = CStr(value)
Dlg1.FText = ""
x = Dialog( Dlg1 )
'NumericKeyboard = CDbl(Dlg1.FText)
If x <> 0 Then
'SetOEMDro(DRONum,CDbl(Dlg1.FText))
Code Dlg1.FText
End If
End Function
Select Case Action%
Case 1
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
   End If
End If
Enable =1
End If
If ControlID$ = "butX" Then
value = CStr(value) + "X"
Enable =1
End If
If ControlID$ = "butY" Then
value = CStr(value) + "Y"
Enable =1
End If
If ControlID$ = "butZ" Then
value = CStr(value) + "Z"
Enable =1
End If
If ControlID$ = "butA" Then
value = CStr(value) + "A"
Enable =1
End If
If ControlID$ = "butF" Then
value = CStr(value) + "F"
Enable =1
End If
If ControlID$ = "butS" Then
value = CStr(value) + "S"
Enable =1
End If
If ControlID$ = "butM" Then
value = CStr(value) + "M"
Enable =1
End If
If ControlID$ = "butSp" Then
value = CStr(value) + " "
Enable =1
End If
If ControlID$ = "butG" Then
value = CStr(value) + "G"
Enable =1
End If
Enable = -1
End If
'MsgBox Dlg1.FText
Case Else
End Select
'Wert zurückgeben
If Enable = -1 Then
Enable = value
End If
End Function
« Reply #4 on: May 20, 2023, 12:01:14 PM »
Good evening
TPS I tested the code works perfectly,
thank you once again for the help :) :) :) :) :) :) :)
« Reply #5 on: February 11, 2024, 09:14:11 PM »
Hello,
The Keyboard / MDI screen is exactly what I need. Could someone give clearer instruction right from the start  for a novice?
Thanks in advance
Offline TPS
  •  2,601 2,601
« Reply #6 on: February 12, 2024, 02:31:48 AM »
ok like written earlier in this post, put this code:
Code: [Select]
'TPS 01.12.2017
'numerische Eingabe
Dim title As String
title = Header
End Dialog
Dlg1.FText = ""
x = Dialog( Dlg1 )
If x <> 0 Then
Code Dlg1.FText
End If
End Function
Select Case Action%
Case 1
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
   End If
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable =1
End If
Enable = -1
End If
'MsgBox Dlg1.FText
Case Else
End Select
'Wert zurückgeben
If Enable = -1 Then
Enable = value
End If
End Function
in a macro in your macrofolder like: C:\mach3\macros\your profile name\numerickeyboard.m1s
if you put following code into a transparent button over the X-axis dro
Code: [Select]
Sub Main
End Sub
#Expand <\..\..\macros\yourprofile\numerickeyboard.m1s>
the red number is the OEMDro you want to edit.
« Last Edit: February 12, 2024, 02:33:37 AM by TPS »
« Reply #7 on: February 13, 2024, 12:35:16 PM »
Thank you for the quick reply !
