Hello Guest it is October 12, 2026, 07:33:05 AM
Author Topic: Message Box with Cancel?  (Read 40680 times)
Re: Message Box with Cancel?
« Reply #30 on: February 10, 2018, 12:40:07 PM »
Daz,
Here is my entire macro.  The repeat command works, to test this I kept hitting cancel and it pops back up as expected.
However, when I input a number, it acknowledges that number until it reads the "until" line, then the variable "ActualTool1" returns an ERROR instead of #.
--What is the actual tool?
function m110()
repeat
     local ActualTool1 = wx.wxGetNumberFromUser("What tool is in the turret?", "Tool # ","Current Tool", 1, 1, 6) -- Default, Min, Max.
until (ActualTool1 ~= -1)
mc.mcToolSetCurrent(inst, ActualTool1)
end --m110
 m110()
end
Chad Byrd
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #31 on: February 10, 2018, 01:01:59 PM »
Oh I see now, der me....   you cannot run any of the getnumberfromuser or textfromuser from a macro. just remembered I tried to use this a while back. the lua stack is a cutdown version and wont allow dialogs like this.
DazTheGas
« Reply #32 on: February 10, 2018, 01:33:07 PM »
 This was allowing me to get text and numbers and use them.   Just not inside the repeat command.
Chad Byrd
« Reply #33 on: February 10, 2018, 01:53:36 PM »
You might try this.... instead of doing the repeat loop in the macro, have a separate function to check the number entered and another function to pop up the message box if needed.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #34 on: February 10, 2018, 02:19:09 PM »
Here you go http://www.dazthegas.co.uk/forumanswers/m110.mp4 perhaps this will explain the error i was on about.
DazTheGas
« Reply #35 on: February 10, 2018, 04:10:27 PM »
Daz,
Thanks for the video.   I had that error pop up yesterday, didn't know what it was.   I'm guessing once you close it out the first time, you're good to go until Mach gets shutdown and turned back on again?
Chad Byrd
