Hello Guest it is November 01, 2026, 10:12:15 AM
Author Topic: LC 2.080 not posting full Gcode  (Read 10475 times)
Elnino
« on: July 04, 2007, 06:46:16 PM »
I'm trying to convert a simple DXF into Gcode and it seems to only want to write 50 lines of code.  I'm not sure if it's crashing out and failing to write the file or if Is this a deliberate thing?
The job is 4 layers - Holes, inside, slots and outside.  There are only 2 chains on the inside (cut second).  It finishes the first chain and then has a few G40's and G42's and that's it.  Seems a little weird so at the moment i'm seeing it as a bug and not a feature.
This same DXF worked ok on previous versions of LC ok.
I can post the DXF if you like.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LC 2.080 not posting full Gcode
« Reply #1 on: July 04, 2007, 07:40:19 PM »
Hi, Elnino
Post your DXF
Thanks, Chip
« Reply #2 on: July 04, 2007, 07:57:27 PM »
I think the free version of LC will only give 50 lines. If you have bought a Mach licenses, I think it should work.
« Reply #3 on: July 05, 2007, 11:40:32 AM »
Yup... If there is no Mach3 Lic on your system it will only output 50 lines of code... If you have a Pro lic that will also Lift the 50 line limit...
Brian
www.newfangledsolutions.com
www.machsupport.com
