Hello Guest it is November 13, 2026, 09:41:53 AM
Author Topic: Simple toolchange position  (Read 116107 times)
Re: Simple toolchange position
« Reply #60 on: January 08, 2008, 04:58:57 AM »
Hood, I tinkered a little with a Picaxe micro controller some time back. Very little actually. It was a similar coding, some form of Basic I guess.
I used the ' to "comment"  lines very often as you do.  ( seems to do the same thing in G code.
RC
« Reply #61 on: January 08, 2008, 07:33:19 AM »
Another thing, step thru the program in editor and when yu get the syntax eror, it will highlite the trouble. Also, hoover over the lines with your cursor. THis doesn't work if it is a problem and Mach is trying to run it. Neither does editing the code from the error message pop up I dont think. You have to close the error and po up, then open the script in editor or button editor.
« Reply #62 on: January 08, 2008, 07:58:06 AM »
I found out the hard way about trying to edit the error pop-up....bout wore my mouse out.
Thanks for the tips.
I'm starting a new thread in LCam forum, from .dwg file to LazyCam to M3Turn.
Check it out, I'm certain you and Chip can get me "sorted".
Thanks Brett,
RC
« Last Edit: January 08, 2008, 08:29:52 AM by Overloaded »
« Reply #63 on: January 08, 2008, 09:14:22 AM »
Thanx Brett, just what I was hoping for.
Mabye Ill try to make this happen on Q by myself....any chance of sucseeding you think?
Best reg
Cory
« Reply #64 on: January 08, 2008, 09:52:17 AM »
Sure Cory, nothing to it but to do it.
Offline olf20
  •  325 325
« Reply #65 on: January 11, 2008, 06:15:40 AM »
Brett, Great thread!
I got my game pad and setup keygrabber using the guidelines in the thread. I got most everything working that I need / want.
One question I have is I don't fully understand the difference between the joystick and the buttons on the game pad.
In order to get my jogging rate to change I had to put my X & Y on the buttons. Then I could program another button to increase / decrease the jogging rate. However I'm out of buttons and have the joystick setup for my Z axis. The Z axis works fine, but I can not control my Z jogging speed.
Any thoughts?
Thanks olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #66 on: January 11, 2008, 07:23:54 PM »
olf20, Are your joysticks analog?
Offline olf20
  •  325 325
« Reply #67 on: January 12, 2008, 06:25:11 AM »
Thanks for the reply!
How do I know if its analog? Is there some way of
determining using keygrabber??
Thanks olf20
« Reply #68 on: January 12, 2008, 09:19:41 PM »
I don't think you can tell in Keygrabber, should say on the game pad somewhere and may have a button to choose analog.
« Reply #69 on: February 08, 2008, 12:30:12 PM »
Hi guys.
I put a button on my screenset using Screen4, as you brilliantly described Hood, thanx, but when i paste the vb script I found in an earlier post of this thread, and try to run the script I get the error msg: "Cannot use g53 Incremental"
Am I missing som settings in config here?
And while we are at it, just for fun I tried to load the screenset for Q (as it has the Big tool button on in,that i like) could this actually work?
Cory
« Last Edit: February 08, 2008, 12:33:07 PM by corydoras »
