Hello Guest it is November 22, 2026, 07:06:47 PM
Author Topic: X & Y motors mounted backwards, how to orient everything??  (Read 9783 times)
« on: December 03, 2017, 03:52:42 PM »
I have my Y axis motor on the back of the machine, X axis motor on the right side. you'd think just checking 'reverse' in homing/limits would be all it takes right? unfortunately, no :( :(
its either 1 thing or another. the jogging is backwards, the table display, or the actual parts. is there any way to actually make this work?
Re: X & Y motors mounted backwards, how to orient everything??
« Reply #1 on: December 03, 2017, 10:18:01 PM »
Stand at the machine, so that the X axis is moving left to right.
When you jog in the X+ direction, the spindle should move to the right, and the DRO's should be counting up. The toolpath display should also show movement from left to right.
When you jog the Y axis, the spindle should move away from you, with the DRO's counting up. And again, the toolpath should match.
This assumes a moving gantry type machine, where the spindle is moving.
When questions like this come up, 99.9% of the time, the issue is the machine is setup with one or more axis moving the  wrong way, even though the user thinks it's right.
« Reply #2 on: December 04, 2017, 12:04:48 AM »
you can define it anyway you please but there is a conventional assignment as ger21 has just pointed out. If you ever go to import some Gcode or get a wizard
to make code for you you'll need to stick to the conventional setup. It can be confusing.
A little tip that may help while you get it settled is to take an A4  size piece of paper and draw on it the X Y Cartesiasn co-ords just like a graph you did at school
and put that down on the mill table.
« Reply #3 on: December 04, 2017, 01:10:09 PM »
Thanks for the replies everyone. I finally got it figured out.
I admit, part the reason was the fixed gantry confusing me (total newbie mistake). When the table was moving my mind wasn't on the same page as the table display. it assumes a moving gantry basically. hope that makes sense. so glad to get over this hurdle :)
jogging, table display, and actual parts work as expected now. I just have to keep reminding myself the crosshair is the spindle location on the table, and the gantry isn't moving hahhaa
« Last Edit: December 04, 2017, 01:14:22 PM by scott0999 »
