Hello Guest it is November 07, 2026, 09:56:27 PM
Author Topic: Homing Z-Axis during G-Code process  (Read 12284 times)
« on: July 02, 2007, 04:33:05 AM »
Hi I am New to the group and this is my first question. I have a converted Proxxon MF70 . All homing and Soft Limits are properly set up. Everything works my question is more this: When I am trying to Home in the middle of the G-Code processing the Z-Axis won't pull up   :o to 0 first leading to scratch the piece I was working on. Is there somewhere a way to tell it that when "Homing" is pressed the fist thing would be Zeroing the Z-Axis ?  ???
Re: Homing Z-Axis during G-Code process
« Reply #1 on: July 02, 2007, 07:00:40 AM »
Hey Csaba,
    Are you doing this with the ref. all home button? If so, you can go in the button and edit the vb script. Also, you might want to look at configuring your safe Z.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #2 on: July 02, 2007, 01:36:39 PM »
I belive in Mach 2 I had this problem with "Home" button where it would move all the axis at once, so the Z would scrap my part while the X and Y moved.
You can fix this by editing the button
Just what Brett said:
-Go to "operator"
-"Edit button Script"
-and press on the button
for "Ref All Home", this will move X, than Y, than Z, than A, and will wait for them to hit home before doing the next axis:
Add this if it's not there:
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Also as Brett said:
check if you're Z Safty is on:
-"Config"
-"safe Z setup"
-Safe Z and Optional "Goto safe Z when Stop Button is hit"
« Reply #3 on: July 02, 2007, 04:04:39 PM »
Thanks guys ! Now it's behaving very bravely. This group is very nice thanks again. It was just a little button that I didn't know what it was for. But I'm getting the hang of it slow and easy. The Safe -Z was not enabled. But now it works like a charm. Great Product, great Support I'm glad I 've chosen this product.
