Hello Guest it is October 22, 2026, 01:53:25 PM
Author Topic: Setting zero positions for G30  (Read 18942 times)
Re: Setting zero positions for G30
« Reply #10 on: April 26, 2023, 10:22:50 AM »
Glad to see it updated but I think there are still errors in the G30 references in the manual. Maybe I just don't understand what I'm reading.
If I omit the P# (as the Fusion Post Processor does too), it doesn't default to the P2 location. It uses what is stored in the P1 location. That is what it is doing in my Mach4 install.
So, is what I have highlighted in yellow incorrect?
Kenny
GOOMBA
« Reply #11 on: April 26, 2023, 12:46:21 PM »
Okay I think this revised version should answer any questions.
« Reply #12 on: April 26, 2023, 12:53:25 PM »
Nice to see it correctly documented  :)
Kenny
« Reply #13 on: April 26, 2023, 06:46:22 PM »
I fixed the GCODE manual, should be updated in new builds.
I'll also attach it here, let me know if you guys need anything changed.
Then the date on the front cover should get bumped to the date of the change.
The manual should also have a version number and a changelog of what changed in the manual between versions.
