Hello Guest it is September 25, 2026, 05:19:14 AM
Author Topic: Local rotated system ang G68 doesn't work  (Read 9068 times)
« on: November 07, 2017, 01:27:17 AM »
Hi
Im new to the mach 3 work and just have completed building my machine.
I'm trying to rotate my x-y plane. I give the mach 3 the lift angle or trying to write G68 command. The DROs of coordinates actually moving on both axes when im pressing one arrowkey but the machine is moving straight only on one axis.
Anyone have a solution?
  •  9,373 9,373
Re: Local rotated system ang G68 doesn't work
« Reply #1 on: November 07, 2017, 03:00:50 AM »
I think Local System Rotate is one of those commands that needs a mach3 license to operate.
(This thread may be of interest to you http://www.machsupport.com/forum/index.php/topic,22932.msg160769.html#msg160769)
« Reply #2 on: November 07, 2017, 08:35:49 AM »
Hi
But i have a lisence. If the lisence is not appropirate so how do i can move my machine and control its board?
« Reply #3 on: November 07, 2017, 10:53:36 AM »
just to double check go to Help/About Mach3 CNC Controller and it will show the name to whom it is licenced. Is it your name?
Mach will still work in absence of a licence but in Demo mode it is limited to 500 lines of Gcode.
