Hello Guest it is November 03, 2026, 03:36:17 AM
Author Topic: text writev4  (Read 12647 times)
text writev4
« on: October 19, 2017, 06:16:55 AM »
Hello,
I have just purchased a licence for mach3 and a small 3 axis cnc, mainly for engraving but also so that my son gets some experience programming. When I tried the demo version of mach3 I tried the write wizard and it seemed simply enough, enter all the information press the write button which takes you back to mach3 and a pre written programme albeit with lots of 0's in the demo version. Now I have the full version it doesn't appear to be working. I enter all the information followed by enter each time, press the write key and nothing happens.What am I doing wrong please.
Jon
  •  9,375 9,375
Re: text writev4
« Reply #1 on: October 19, 2017, 06:30:58 AM »
Have you entered the Direction ?
Re: text writev4
« Reply #2 on: October 19, 2017, 07:34:35 AM »
If it's not working, you are missing a setting that's required. Sometimes it can be hard to see them all.
Re: text writev4
« Reply #3 on: October 19, 2017, 08:28:31 AM »
where would i post a direction, there doesn't seem to be an option. i would have thought that in english words would naturally start on the left.
Jon
Re: text writev4
« Reply #4 on: October 19, 2017, 08:31:18 AM »
ok i see it, 0 90 180 270. but still when i press write nothing happens. I know its just me and thanks for the response.
Jon
Re: text writev4
« Reply #5 on: October 19, 2017, 09:42:15 AM »
You're still missing something....
Re: text writev4
« Reply #6 on: October 19, 2017, 10:47:38 AM »
Hi, if you reset the reset button you can not generate a code.
You must enter everything you need then select the font and finally press "Write"
After pressing "return to Mach3", the Gkod will be generated
