Hello Guest it is October 24, 2026, 08:48:55 PM
Author Topic: Work offsets not being saved  (Read 14536 times)
« on: June 28, 2007, 09:11:59 AM »
My work offsets are not being saved even though MACH3  version .080 says they are being saved.  Am I not holding my mouth right or is there a secret to this?  Thanks.  Mike
Re: Work offsets not being saved
« Reply #1 on: June 28, 2007, 10:04:04 AM »
Did you try changing the settings under the general configs?
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 28, 2007, 01:06:30 PM »
Brian
I'll try that this evening.  Thanks.  Mike
« Reply #3 on: June 28, 2007, 01:46:40 PM »
Axis DRO properties, bottom right corner.
« Reply #4 on: June 29, 2007, 06:49:06 AM »
I tried all the suggestions, nothing worked.  I looked through the files, particullarly mach3mill.xml but could not file the entries that should be modified.  What file(s) are modified for tools and work offsets?  Thanks.  Mike
« Reply #5 on: June 29, 2007, 10:16:45 AM »
Fixture.dat is the file that the offsets are saved in...
Also please get the latest version and see if that will fix your problem
Brian
www.machsupport.com
« Reply #6 on: July 02, 2007, 10:08:46 AM »
Problem was that box was checked was "copy g54 from g59.253 on startup".  Unchecked that and things were fine.  Thanks to all.  Mike
« Reply #7 on: July 02, 2007, 06:11:23 PM »
P38nut, This is just another suggestion ! Don't get in the habbit of using g54 in your programs, reason being is that I leave g54 in machine dim or zero'd out and insure that g59.253 is also zero'd and then when i start machine or need to touch off an odd tool, I can turn on g54 for that purpose then back to the WPO i'm using ! Make sense ?
CRUISER
  Don
