Hello Guest it is November 13, 2026, 01:00:40 PM
Author Topic: Plasma Profile - Can't Get Motors to Respond Correctly  (Read 21711 times)
Re: Plasma Profile - Can't Get Motors to Respond Correctly
« Reply #10 on: October 01, 2017, 03:50:33 PM »
Okay, point taken.  So I disconnected all the motor wires except Z axis and disabled all axis in "Ports and Pins" except Z.  Z should be pins 6 and 7.  DRO shows movement, Z axis doesn't move using the page up page down keys.  I cycled through all the possible pin combos, 2 and 3, then 4 and 5, then 6 and 7 and finally 8 and 9.  No matter what, Z axis doesn't move but DRO shows movement.  If I enable the X axis, no matter what pins I have in the X axis field, the Z axis moves but only if I use the X axis arrow keys.
Dale
« Reply #11 on: October 01, 2017, 03:57:48 PM »
I see why you are confused. I can't think of anything that would cause what you describe.
Do you have a multimeter or an oscilloscope and are you prepared to probe the DB25 plug?
« Reply #12 on: October 01, 2017, 04:09:20 PM »
Yea, I have all that.  Gonna get started on deeper testing tomorrow night and try to figure out WTF is happening.  Thanks for your input today.
I'll post the solution when I find it.  What is crazy is that everything sets up perfectly in the mill profile, motors run beautifully.
I'll find it.
Thanks.
« Reply #13 on: October 01, 2017, 04:54:14 PM »
one thought is that maybe the voltage of the PC is less or at least differ from the previous one.
I believ Gecko pride themselves on the devices being able to accept 3.3V or 5V TTL, but maybe
you have an earlier model G540.
« Reply #14 on: October 01, 2017, 05:45:39 PM »
Does anyone using a Gecko G540 have a good working Mach3 plasma profile xmg file that you could email me?  Seems like this problem is related to that since all the motors work perfectly with a mill profile.  I'll post an email address if anyone can help.   Thanks
Dale
