Hello Guest it is November 13, 2026, 01:30:56 PM
Author Topic: help whit signal step  (Read 18195 times)
Re: help whit signal step
« Reply #10 on: September 24, 2017, 10:21:17 PM »
Ok, could you provide me the documentation or the connection diagram, please.
« Reply #11 on: September 24, 2017, 10:30:38 PM »
I think I would try, even temporarily a 47k resistor, only need be a low power type, between the base of Q1
and the emitter of Q1. If there is indeed a problem that the transistors are not switching Q1 will be the most
sensitive. Its so simple to try...might as well give it a go.
