Third party software and hardware support forums. > dspMC/IP Motion Controller
Error after Update to Mach4 3481 and newest dspMC Plugin
dunnitagain:
After Upgrading from Mach4 2480 to 3481 and Plugin 2.01.70 . Mach wont stay connected to the dspmc , Error says dspmc not found , then it will hook up for about 5 seconds and show it
in the History Line . It shuttles back and forth so fast you can see it read out. Mach 2480 and old plugin were solid as a Rock!
I cant figure it out? Is it in Config or my Ethernet hardware?
Vital System Support:
you only need update mach4 if required. should not need newer plugin. do you still have the old plugin? If you upgrade the plugin, you must update the firmware as well which is a risky thing as it may brick the controller if not done properly. the safest way to upgrade the firmware is to completely disconnect the controller from all plugs and leave only green power and Ethernet plugs connected. when new firmware is flashed successfully, disconnect the green power plug and reconnect after few seconds and make sure the new version shows up in the vsiDeviceManager on network scan.
dunnitagain:
My plugin was 112515. Are you saying that I need to Update the firmware on my box ? Or do I need to revert my Pluggin ? What about the newer features of the newest Plugin?
yes in order to use new features and bug fixes you will need to update the controller firmware. follow the instructions I mentioned in the previous post as well as in the vsiDeviceManager documentation which describes the steps to flash a new firmware.
dunnitagain:
Reflashed the box to the new firmware version and it works great now!
Navigation
[0] Message Index
[#] Next page
Go to full version
