Hello Guest it is November 13, 2026, 09:37:47 AM
Author Topic: Thrading on mach 3 with ss and c10 bob  (Read 24110 times)
Re: Thrading on mach 3 with ss and c10 bob
« Reply #10 on: September 12, 2017, 12:44:58 PM »
From what I recall, from a along time ago when we were fixing threading , what I say is true as it applies to the internal threading
code.
I would have to look through a lot of notes to see if my exactly wording is correct....I think so as the words are not mine.
« Reply #11 on: September 13, 2017, 03:31:43 PM »
Best regards:
I change the configutarion and no matter the valor tahta i put , the pitch threading are the same.I send two photos.
Thanks for the help
Offline rcaffin
  •  1,073 1,073
« Reply #12 on: September 13, 2017, 04:46:12 PM »
Tricky stuff!
If you command S300, S400, S500, what revs appear on the screen DRO?
Roger
« Reply #13 on: September 13, 2017, 07:51:25 PM »
If i put s500 in the dro shows 600
Deimos
Offline rcaffin
  •  1,073 1,073
« Reply #14 on: September 13, 2017, 10:34:56 PM »
Ok, but what about S300, S400, and what are the exact values, not rounded off?
Roger
« Reply #15 on: September 17, 2017, 11:41:08 AM »
i set the speed manually.Th diffrence it´s about 50-100 rpm
Thank´s
Offline rcaffin
  •  1,073 1,073
« Reply #16 on: September 17, 2017, 03:48:32 PM »
>> OK, but what about S300, S400, and what are the exact values, not rounded off?
If you want help, you need to help the people answering you with the information requested. Otherwise we cannot help you.
Roger
« Reply #17 on: September 18, 2017, 07:28:17 AM »
Best regards:
If i turn the bottom of the lathe and set the speed to 300 (For example) Read the dro´s mach3 and try to adjust to 300 the difference it´s about 300=350, 400 rpm .The maximun preccission that i can make it´s about 10 -15 rpm (If the speed it´s 300 rpm i can make 310 rpm, i  only c3 index card and the disk to calculate the rpm)
Cheers and many thanks for you help
