Third party software and hardware support forums. > CS-Lab
CSMIO IP/M - No connection / Problem with IP Adress?
MoZqUiTo:
Hello at all,
I try to set a new machine but I can´t connect to CSMIO Controller. The Device is not found.
I set the IP Adress of the network controller to 10.1.1.1 and subnetmask to 255.255.255.0 as the manual is telling.
The Computer (Windows 10) is connected to the controller with the needed crossover cable.
When I start the machine the LED on the crossovercalbe is flickering as normal, trying to get connection. After a while it just stays on, no more flickering.
At the command box after entering arp /a to show all connected devices I just found a static adress 10.1.1.255 but not the needed dynamic 10.1.1.2 of the machine.
It´s like the machine is not connected. Of course I also can´t ping the machine.
I tried 2 different cables and computers. Did somebody have the same problem or can help me? I need a solution. This ist the 4th machine we set, but never had such problems.
mark4:
hi i dont know if this will help or not but i have set up a few csmio/ip-a and they dont require a cross over cable just straignt through however if you are using a cross over cable and dont need one that could be your problem.
mark
zmnck:
Hello,
Try to update new firmware from cs-lab.eu !
Cheers!
ped8015:
I upgrade from mach3 to mach4 due to the auto update of win 10. everything was running fine before this. I did not feel like restarting windows back and could not downgrade to the previous version . thought mach 4 would be the easier way to go.
I have been unsuccessful in get the CSMIO/IP-M to work with mach4.
I am able to ping the controller. I am able to get the spindle to run.
Unable to see IO (after mapping) in diagnostics, unable to get stepper motors to move. mach4 freezes when I try to select motion device. the firmware sure looks like it is made for servo and not stepper so I think something is not right here... setup_csmio-ip-m-2.854 is what I currently using.
I have uninstalled/reinstalled mach4.
Does someone have mach4 running with csmio/ip-m??
TPS:
have you checked CSMIO webside for the actual verstion? actual version is 3.016 or so.
Navigation
[0] Message Index
[#] Next page
Go to full version
