Hello Guest it is October 22, 2026, 08:53:44 PM
Author Topic: subroutines?  (Read 18131 times)
Re: subroutines?
« Reply #10 on: July 15, 2017, 09:13:20 AM »
For my Test i used the original subroutine Test how you can find under the mach4/subroutine folder!
And normaly this should work!?!
Offline smurph
  •  1,575 1,575
Re: subroutines?
« Reply #11 on: July 15, 2017, 01:50:19 PM »
Nothing has changed.  Subroutines work in Hobby with M98 and M99, just not with G65 and G66.  Also, conditional G code is an industrial feature that is not in hobby.  What you are seeing is the WHILE (line 28) in the embedded subroutine causing the "feature not licensed".
Perhaps the example is not the best.  I will make it so that it works in hobby by taking out the WHILE loop.
Steve
Re: subroutines?
« Reply #12 on: July 15, 2017, 05:28:28 PM »
Hi Steve,
thanks for your information! It works!
At my test´s with the new develop version i had no own program by my hand at this moment and i always tried with the "subrotine test" so the stone becomes to run.  ;)
Sorry!
Best regards
Uwe
