Hello Guest it is October 11, 2026, 11:50:10 AM
Author Topic: MACH4 CRASHES WHILE RUNNING 5 AXIS TOOLPATH  (Read 31253 times)
« on: June 13, 2017, 05:25:11 AM »
Mach4 Suddenly crashes while runnning a 5 axis simultaneous toolpath. on windows 10 it was happening. give me solution.
Offline smurph
  •  1,575 1,575
Re: MACH4 CRASHES WHILE RUNNING 5 AXIS TOOLPATH
« Reply #1 on: June 13, 2017, 05:38:28 PM »
I hate to say this but...  you are never going to get a response without providing more information.  Mach build?  What motion controller?  Machine setup?  Also, when asking for help, examples are suggested.  It is proper etiquette.  Then maybe someone can possibly help you.  Otherwise, expect your post to go unanswered.
Steve
« Reply #2 on: June 14, 2017, 04:43:19 AM »
The version and all the details are as follows
Mach Build 4.2.0.2914
Motion controller WIXHC MK6
Machine Setup 5 Axis XYZAC
and now help me mach4 is crashing while running 5 axis toolpath i broke 5 tools while doing this.
Offline Stuart
  •  311 311
« Reply #3 on: June 14, 2017, 11:19:14 AM »
Say please and you may get some help
Demanding help is not the way to get it from other users
« Reply #4 on: June 14, 2017, 11:36:27 AM »
and now please help me mach4 is crashing while running 5 axis toolpath i broke 5 tools while doing this.
Offline smurph
  •  1,575 1,575
« Reply #5 on: June 14, 2017, 11:51:22 AM »
Still no example?  Dude, I can't magically reproduce your problem.  You need to post your profile (help->support->package profile) and provide a file that crashes.  Why?  Because everything file I run doesn't crash.
Steve
« Reply #6 on: December 23, 2023, 02:13:30 AM »
Hear! Hear!.. I'm w/ ya..   5 axis kinematic's is currently what is holding up my purchase of a decent 5 axis CAM. I haven't found one that does it for you [ so mach doesn't have to] and mach doesn't do it so right now.. mach is really just a 3/4 axis mill, the 4-5-6 axis is only usable either for a 4th rotating axis or to slave motor's, in reality it can't be used as a 5 axis control until this is provided, even if the hardware connected to it has the ability to run 6 motors..
Jerry
mach3 (in my opinion and 4 hobby) cannot control a 5-axis machine!!!
https://youtu.be/oKFM9hivDbA
result: 5th axis skips steps
Offline smurph
  •  1,575 1,575
« Reply #7 on: December 23, 2023, 02:40:12 AM »
You posted a video, a picture, and gave your opinion.  Are you wanting help?  We have people run 5 axis all day every day and it isn't an issue.  My phone would be ringing off the hook if there was an issue.  So we must find out why you are having problems.  So if you are wanting help, if you would please package up you profile (help->support->package profile) and attach that file along with the G code and I will test it.
Steve
« Reply #8 on: December 23, 2023, 03:38:56 AM »
GA-8SR533P ver.3
from LPT via 10kOhm to drivers DRV8825 1/16
17HS8401
Mach3 v.R3.041
Diametr correction axis B =45
« Last Edit: December 23, 2023, 03:43:41 AM by SergeyRJ »
« Reply #9 on: December 23, 2023, 04:48:23 AM »
Steve
Pentium 4  2,2gHz, 1gB, LPT = SPP
now it looks like this:
Dear Steve!
Thank You for Your responsiveness!
« Last Edit: December 23, 2023, 04:57:43 AM by SergeyRJ »
