Hello Guest it is October 12, 2026, 02:52:55 AM
Author Topic: Question about lost steps and CPU cycles...  (Read 17444 times)
Offline Stuart
  •  311 311
Re: Question about lost steps and CPU cycles...
« Reply #10 on: June 03, 2017, 11:02:22 AM »
My 2 cents
When you load mach3 in this case or mach4 to a PC that then it becomes a machine controller and should be treated as such, has as been said no other software should be run not even the file manager
Mine is striped out and has no means of getting on the Internet and nothing else is installed except mach4 for me
No longer do I see it as a pc but the mills controller
