Hello Guest it is November 22, 2026, 02:25:12 PM
Author Topic: Z-axis going down, but not programmed  (Read 14938 times)
Stef
« on: June 21, 2007, 09:44:51 AM »
In a program z-axe start at a save position, then going to Z-0.2.  After this G01 movement in X- and Y-axis.
After a while Z-axe is going minus, but it is not programmed. Z-axe keeps on going down  ??????
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Z-axis going down, but not programmed
« Reply #1 on: June 21, 2007, 01:32:08 PM »
Hi Stef
What ver. Mach3, Post your code, Someone will look at it.
Thanks, Chip
Stef
« Reply #2 on: June 22, 2007, 01:47:59 AM »
Hi Chip,
We are working with mach2
We work on the machine with step-direction steppermotor without encoders.
Stef
« Reply #3 on: August 18, 2007, 11:38:42 AM »
Hello,
The problem above, is the problem with my machine.
The z-axe is going down faster and faster in the matertial, until, ...
Sometimes its works perfect, and sometimes its going wrong.
I have no idea whats happend.
This is my code:
Code: [Select]
G21
G0 G17 G40 G49 G80 G90
G61(CONSTANT CONTOUR OFF OR TURN ON W/G64)
M07(Cooling ON)
(2 1/2 Axis Pocketing)
G55
S1000 M03
G00 Z1.5000
X0.0000 Y-2.2500
G01 Z-0.6000 F30.0
Y0.0000 F50.0
X130.0000
Y-3.0000
X0.0000
Y-2.2500
X0.7500
Y-0.7500
X129.2500
Y-2.2500
X0.7500
G00 Z1.5000
X0.0000
G01 Z-1.2000 F30.0
Y0.0000 F50.0
X130.0000
Y-3.0000
X0.0000
Y-2.2500
X0.7500
Y-0.7500
X129.2500
Y-2.2500
X0.7500
G00 Z1.5000
M05
M30
I hope that someone can help my, it's verry urgent.
Thanks a lot.
Hein
Offline Chip
  •  2,055 2,055
« Reply #4 on: August 18, 2007, 04:24:15 PM »
Hi, Hein
Try this.
G21
G17 G40 G49 G80 G90 ;-----------------------------------------Removed the G0 in this line of Code
M07(Cooling ON)
G55
S1000 M03
G00 Z1.5000
X0.0000 Y-2.2500
G01 Z-0.6000 F30.0
Y0.0000 F50.0
X130.0000
Y-3.0000
X0.0000
Y-2.2500
X0.7500
Y-0.7500
X129.2500
Y-2.2500
X0.7500
G00 Z1.5000
X0.0000
G01 Z-1.2000 F30.0
Y0.0000 F50.0
X130.0000
Y-3.0000
X0.0000
Y-2.2500
X0.7500
Y-0.7500
X129.2500
Y-2.2500
X0.7500
G00 Z1.5000
M05
M30
Hope this Helps, Chip
« Reply #5 on: August 19, 2007, 02:48:50 AM »
one thing that was a problem with me was i had a tool offset set up in the tool table, so i would set my height for z then when the program ran it would do my hieght and add the tool hieght also, i manualy change bits, so i removed the tool hieght from the tool table, problem fixed.
dan
« Reply #6 on: August 19, 2007, 05:09:29 PM »
Hello,
I have removed the G0 code, but the problem is the same.
I have no idea.   ???
Thanks for the help.
mvg
Hein
Offline Chip
  •  2,055 2,055
« Reply #7 on: August 20, 2007, 01:34:41 AM »
Hi, Hein
Try setting you Velocity & Acceleration down in Motor Tunning or Edit your G0's to G01, Your Z up may be slipping causing pos. loss.
Thanks, Chip
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #8 on: August 20, 2007, 03:06:53 AM »
This is sounding more like pull down.
Is the tool fixed in the holder tight.
Is the Z axis moving down with vibration and cutter pull down. Fix a dial clock on the machine to monitor the Z movement.
Graham.
