Hello Guest it is November 13, 2026, 09:40:55 AM
Author Topic: Axis direction doesn't always change  (Read 48242 times)
  •  9,377 9,377
Re: Axis direction doesn't always change
« Reply #10 on: November 09, 2017, 09:46:31 AM »
Hi Martin,
I think Gerry has mentioned the most likely cause of the problem - 3.3V TTL signals where 5V TTL is expected.
Offline Jacko
  •  43 43
Re: X and Y Jogging the wrong way !!
« Reply #11 on: March 27, 2022, 04:03:49 AM »
Hi all,
       Just finished converting a Warco mill to CNC and after the usual tuning all works fine and produces a good result apart from the jog keys send the X & Y in the wrong direction!!
When I toggle the dir active in motor tuning the jog keys then work as they should but when I  machine a part with these settings it comes out a mirror image and upside down.
I am using  Mach 3 with a Windows 10 laptop for the first time with a genuine UC100 controller direct from CNC drive in Hungary.
Any ideas how to reverse the jog keys so they work correctly without changing anything else?
Many thanks
JH
