Hello Guest it is November 26, 2026, 10:55:25 AM
Author Topic: Mach3 500 gcode limit  (Read 10494 times)
« on: April 27, 2017, 09:55:23 PM »
I have bought the license through ebay... sealed copy and all. So yeah I payed around 175$. Everything is working as the program should but I have a limit of 500 lines that Mach3 only reads the rest gets cut off... I've looked for the License Files and have both in the Mach3 folder aswell. "License", and "Mach1Lic". How can I resolve this problem hopefully without having to purchase another License.. and FYI. I'm using it off a computer with no Internet access.
  •  9,379 9,379
Re: Mach3 500 gcode limit
« Reply #1 on: April 28, 2017, 12:22:43 AM »
If you have the file Mach1Lic.dat in your Mach3 folder and you are still limited to 500 lines then it sounds like you may have been sold a bogus license.
Perhaps check the validity of your license with licensing:  http://www.machsupport.com/contact-us/ and then take the matter up with your ebay seller.
(Genuine licenses can be purchased here http://www.machsupport.com/shop/mach3/)
« Reply #2 on: April 28, 2017, 12:36:41 AM »
Thank you. I sent them a message.
