Hello Guest it is April 26, 2024, 06:11:14 AM
Author Topic: Mach3 ignores Z height in Gcode after a while.  (Read 3874 times)
« on: April 26, 2017, 07:41:34 AM »
Hi all.
I made a video explaining what is going on.
https://www.youtube.com/watch?v=QeVdz5GYEEU
Basically I have 15mm of stock, I am cutting through this in Fusion and it simulates fine. I even go 2mm bellow to make sure it goes all the way through.
Problem I am finding is after 10mm, it ignores the Z height in the Gcode.
I can see the Gcode telling Mach to go to Z-12 and it stays at around Z-10.
Any ideas on what I am doing wrong?
Jack,
  •  9,200 9,200
Re: Mach3 ignores Z height in Gcode after a while.
« Reply #1 on: April 27, 2017, 01:26:15 AM »
Hi Jack,
Welcome to the forum.
If you zip and attach a copy of your Gcode file I will try it here and see if I can identify the problem.
« Reply #2 on: April 27, 2017, 08:30:33 AM »
Hi Jack,
https://pastebin.com/4X3jrHde
Happens around the 4000 line area.
« Reply #3 on: April 27, 2017, 09:36:03 AM »
Just posted this too. Different operation but same result of it stopping at Z-10.something
Only 500 lines or so.
https://pastebin.com/mwZifzwS
« Reply #4 on: April 27, 2017, 10:35:09 AM »
Well now I feel silly.
I previously had it working but I changed bits to something with less stickout.
This meant that while previously I could go down that far, now I can't because it hits the Z limit.
Seams so silly now I think about it xD
Thanks anyway.
  •  9,200 9,200
« Reply #5 on: April 28, 2017, 01:07:01 AM »
 ;D
I am pleased you got it sorted.
