Hello Guest it is October 23, 2026, 06:53:41 PM
Author Topic: mach4 fails on simple sample, that works in mach3  (Read 5632 times)
« on: April 25, 2017, 10:00:51 AM »
I use a little nc-script to test setup and I noticed, that mach4 fails with this sample. First I thought, it fails because of my mistakes during screen editing, but it fails with original screen too.
It breaks always on the same line (G1), but it does not terminate the movement and it fails each run at different coordinates.
When it fails, it looks like someone has pressed the stop button, cause time passed stops counting.
Is there a way to find out, why mach4 fails? Can I enable debugging/logging or whatever?
