Hello Guest it is November 26, 2026, 11:53:33 AM
Author Topic: Scaling Mach3 imported dxf files  (Read 9344 times)
« on: April 24, 2017, 07:34:00 PM »
I have Mach3 and Meshcam. I have bought dxf files off eBay and imported, I seem to have no problems with Meshcam, BUT, when I try cutting I end up with a profile of about 2" square. The dxf files are around 200,000 in I want to cut on a 10" square. Ends up in one corner. I Ave read about everything I can find on scaling and am totally confused.
I would greatly appreciate any help.
Re: Scaling Mach3 imported dxf files
« Reply #1 on: April 24, 2017, 08:34:40 PM »
What size is your stock when you create the g-code in MeshCAM?
Is your machine setup in the same units that you're using in MeshCAM?
« Reply #2 on: April 24, 2017, 09:24:57 PM »
X10 Y10 stock thickness 3/8" everything is in inch,
Dxf file imported values 220,456, 195,434, 0,000
Set scaling to 10X10X0.375
Result is a 2X2 that is unrecognizable
Hope that answers question
Offline rcaffin
  •  1,073 1,073
« Reply #3 on: April 29, 2017, 02:54:51 AM »
You may need to calibrate your axis motors.
Read Mach3 doco for that.
Roger
