Hello
Guest
it is
October 23, 2026, 08:50:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
multiple probe use
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: multiple probe use (Read 11200 times)
thespindoctor
307
multiple probe use
on:
April 20, 2017, 09:32:21 AM »
How do we address a second probe? Do we just use the command and change probe to probe1 for the second probe?
Cbyrdtopper
985
Re: multiple probe use
Reply #1 on:
April 20, 2017, 10:16:08 AM »
You can refer to the Mill GCode Programming Manual page 19. G31, G31.1, G31.2, and G31.3.
You use the same command only instead of G31 you will use G31.# depending on which input you mapped it to, Probe1, Probe2, or Probe3.
Chad Byrd
thespindoctor
307
Reply #2 on:
April 20, 2017, 10:32:42 AM »
Perfect! I was looking in the wrong place making it more difficult than needed!
Fledermaus
215
Reply #3 on:
April 20, 2017, 01:59:19 PM »
Be aware that not all controllers currently support multiple probes, so be sure to test carefully.
Allan
thespindoctor
307
Reply #4 on:
April 20, 2017, 02:45:21 PM »
Thanks my system looks good for more than 1 probe but still need to see if it works.
thespindoctor
307
Reply #5 on:
April 23, 2017, 10:50:02 AM »
G31.1 does not work even though the BOB and ESS have pins connected correctly and the probe lights up on the board and in diagnostics.
It looks like only G31 really works in Mach4 You can have a second probe which is recognized but the probing routine does not work in a G31.1 move.
Guess I will use a switch to go between the 2 probes. Why is it documented in the manual. Even the #variables are not correct. The manual says #5071
and #5071 are for probe1 (second probe) x and y position values but looking at the probing lua code done by Mach4 programmers, those variables
are actually G31 skip signal machine positions NOT G31.1 X and Y probe absolute positions. Hours wasted to figure that out!
Last Edit: April 23, 2017, 10:54:27 AM by thespindoctor
thespindoctor
307
Reply #6 on:
April 23, 2017, 01:43:56 PM »
Looks like ESS plugin only supports one probe. Wired second one to the same port (in parallel) and running G31 works fine with either probe.
Problem solved for now...
thespindoctor
307
Reply #7 on:
April 27, 2017, 07:19:40 AM »
New ESS plugin now works for multiple probes!! YES!!
Print
Pages:
1
Go Up
« previous
next »
