Hello Guest it is October 24, 2026, 10:09:49 PM
Author Topic: MACH 4 ESS PWM Spindle Control HELP!HELP!  (Read 29414 times)
Re: MACH 4 ESS PWM Spindle Control HELP!HELP!
« Reply #10 on: June 08, 2024, 07:34:13 AM »
You need to enable PWM Spindle pin.
Arturo Duncan
https://cnc4pc.com
« Reply #11 on: June 08, 2024, 12:43:03 PM »
Thanks Arturo. I did finally realize that I had not enabled that output. After enabling it, I spent a lot of time trying to figure out what I needed to do on the Mach side (what Mach output to assign it to etc.). As it turns out, there is not one to select for the pwm signal. I finally got my c41s control board to output a variable voltage. Nothing is installed in an electronics cabinet yet, and I still need to make a spindle adapter for my machine and my new spindle, so I will have to test the real setup later. I appreciate you taking the time to respond.
