Hello Guest it is November 27, 2026, 04:13:48 AM
Author Topic: Mach4 M6 Macro problem  (Read 21569 times)
Offline smurph
  •  1,575 1,575
Re: Mach4 M6 Macro problem
« Reply #10 on: April 30, 2017, 12:57:16 PM »
Sure, you can put that API call in a M code macro script.  Then just call that M code in your G code.
If I don't have a fixture setup, I typically start my machine and do a tool change via MDI to my edge finder or probe anyway, no matter what tool is the current tool.
Steve
Offline Stuart
  •  311 311
« Reply #11 on: May 01, 2017, 01:48:13 AM »
Berths
Leave it in
If you have multiple ops in your code e.g. A adaptive roughing run the a Finnish contour both useing the same tool it save the mill going to G28 for a tool change
« Reply #12 on: May 01, 2017, 07:08:50 AM »
I am learning, not arguing.
If the same tool is used for the finish operation why would the CAM program insert a tool change?
I started to insert:
T1 M6
G43 H1
I just stops at the start of the program and a cycle start continuous but it guarantees that the program will not run without stopping to get the right tool afterwards.
Bertho
Offline Stuart
  •  311 311
« Reply #13 on: May 01, 2017, 08:48:40 AM »
post deleted
« Last Edit: May 01, 2017, 09:01:27 AM by Stuart »
